Latest Version Crashes WinXp SP3
Just started using this, downloaded the latest version.
Windows XP all up to date.
Random crashes with click and drag, no error code, just the "encountered a problem and needs to close" message"
Hi Lakes,
The first thing I would try is to clear your browser cache and download the zip file again. Then extract the contents of the zip to some convenient folder.
Write back if that doesn't help.
Cheers,
- j
Works fine on my laptop,(same Xp etc) must be something on my main PC.
Error Code:
Hi Lakes,
Thanks for posting the error message. It looks like the zip file extraction on your main PC is not correct. For example, the dll in the posting should have the path
[fritzing unzip folder]/lib/imageformats/qjpeg4.dll
but it looks like the extraction has mangled that path down to a file named
libimageformatsqjpeg4.dll
You might try using a different zip utility.
Cheers,
- j
Post a Reply
Please login to post a reply.
