Arduino Ethernet Shield R3 - PCB?
Dave Collins 7 years, 1 month ago
Dave Collins
   I am trying to make a shield that will plug into an Arduino Ethernet Shield R3.  It will basically just have a few connectors - will reduce the nest of wires in the camera.
   When I choose the Arduino Ethernet Shield in PCB mode, it seems to be an older version - the pinouts don't match around the power section.
  Is there any way to get an updated layout?
Danke!
Dave Collins
bluearc 7 years, 1 month ago
Hej Dave,
the version in the core is not the newest shield but you have luck because i'm just now working on the new version. so if you could give me a mail adresse i can send you the r3 shield as soon as possible.
greetings
fabian
oh, just send an email to info(at)fritzing(dot)org
Dave Collins
Thanks!  Will do.
Ulrico 6 years, 10 months ago
Hallo,
könnte ich auch die neue Datei mit der neuen Version des Arduino-Ethernet-Shields bekommen?
Grüße und vielen Dank schon im Voraus
Ulrico.
