Font
Hunmin Koh 6 years, 1 month ago
Hunmin Koh
Hi. So I created SVG icon for A4988 Pololu board in Inkscape
https://drive.google.com/file/d/0B7PcbUKxJf6yYjdVQTNTVlg0SGs/edit?usp=sharing
but the text in the file becomes like this in Fritzing
https://drive.google.com/file/d/0B7PcbUKxJf6yRGlUaVk0eHJEMFU/edit?usp=sharing
Text in both side is in a same layer using ocrA font. Does anyone know how to solve this?
Jonathan Cohen 6 years, 1 month ago
Hi Hunmingo,
Because we can't guarantee that a particular font will be available across machines, we only use Droid or OCRA fonts, which are open source and travel with Fritzing. If you can't live with either of those fonts, you could convert the text to plain svg element.
Hunmin Koh
But...but.... I did use OCRA font... (cry)
Please post the svg files, and I will take a look.
  • j
Hunmin Koh
Here you go!
With a few exceptions, SVGs in Fritzing must conform to the SVG 1.2 Tiny specification. Text flow () elements are outside that spec. Basically you want to stick with simple elements.
  • j
The text editor in this forum eats up angle brackets, so I will use curly brackets instead.
With a few exceptions, SVGs in Fritzing must conform to the SVG 1.2 Tiny specification. Text flow {flowRoot} elements are outside that spec. Basically you want to stick with simple {text} elements.
