Pushbutton and matrix
Max Chaumon 5 years, 2 months ago
I'm enjoying my brand new Creator Kit and have a question:
Using the matrix as a starting point, I want to insert a pushbutton and switch between 2 images with this button. I added a switch connected on one side to GND and on the other side to pin18. A 100kOhm pull-up resistor connects to 5V.
I've adapted the matrix program to switch between images when the pushbutton is pressed. The program works because if I bypass the pull-up resistor with pin18, the matrix animates.
It seems like the resistor is too high. If I test with pin18, starting from 5V, as soon as I jump over the resistor, it stops working. I tried (unconvinced) with a 220Ohm resistor, which didn't change a thing. Can you explain to me why this is not working?
I just posted the breadboard here http://fritzing.org/projects/pushbutton-matrix
Many thanks!
Stefan Hermann 4 years, 11 months ago
Stefan Hermann
Hello Max,
sorry for the late reply. We didn't see the question.
It looks that the GND connection is missing. Connect a GND to the blue marked breadboard row – then it should work.
Thank you and have a great day,
Stefan"
