Mac Fritzing Quits unexpectantly
Spartan001 8 years, 11 months ago
My mac Fritzing Quits unexpectantly every time it Boots any suggestions?
Jonathan Cohen 8 years, 11 months ago
Hi Spartan,
We're not seeing the problem here.  Have you tried downloading Fritzing from the site again?
If that doesn't help, can you give us more information?  For example, which version of Fritzing, and which Mac OS you're using?  How far does the program get before it quits: do you see the splash screen?
Thanks.
- j
One other possibility--do you have Universal Access turned on?  There is a known issue that Fritzing crashes under Universal Access:  http://fritzing.org/forum/thread/7/ and if you're a Cinch user, this is the same problem, because Cinch requires Universal Access.
- j
bruffner 8 years, 10 months ago
I am having issues with a specific set of actions on Mac SnowLeopard.
Here is a video of the bug on youtube:
http://www.youtube.com/watch?v=74JjIZPL0tM
Here is the stack trace:
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
0   ...rack-software.testgenplugin 0x2fcab75f ARRAY_GenAppendI + 17
1   ...rack-software.testgenplugin 0x2fcf21b7 IMAGE_BBufFmtAdd + 45
2   ...rack-software.testgenplugin 0x2fbc4a37 TGIMAGE_Init() + 25
3   ...rack-software.testgenplugin 0x2fc920d6 CTGEQ::Initialize() + 354
4   ...rack-software.testgenplugin 0x2fc9a94f InitializeNetscapePlugin() + 11
5   ...rack-software.testgenplugin 0x2fc840ed NPP_Initialize + 11
6   ...rack-software.testgenplugin 0x2fca8b7b NP_Initialize + 251
7   QtWebKit                       0x00c63893 qWebKitVersion() + 3331
8   QtWebKit                       0x00c63cff qWebKitVersion() + 4463
9   QtWebKit                       0x00aee8f7 WTF::fastRealloc(void*, unsigned long) + 5135847
10  QtWebKit                       0x00ae8fb2 WTF::fastRealloc(void*, unsigned long) + 5112994
11  QtWebKit                       0x00af5bd4 WTF::fastRealloc(void*, unsigned long) + 5165252
12  QtWebKit                       0x00c2c724 qt_dump_resource_load_callbacks(bool) + 20004
13  QtWebKit                       0x009b4903 WTF::fastRealloc(void*, unsigned long) + 3849715
14  QtWebKit                       0x009bba4b WTF::fastRealloc(void*, unsigned long) + 3878715
15  QtWebKit                       0x00b8701f WTF::fastRealloc(void*, unsigned long) + 5760271
16  QtWebKit                       0x00a67b23 WTF::fastRealloc(void*, unsigned long) + 4583443
17  QtWebKit                       0x00a6894d WTF::fastRealloc(void*, unsigned long) + 4587069
18  QtWebKit                       0x00a69f27 WTF::fastRealloc(void*, unsigned long) + 4592663
19  QtWebKit                       0x00a6a726 WTF::fastRealloc(void*, unsigned long) + 4594710
20  QtWebKit                       0x00c37ee5 qt_drt_pauseAnimation(QWebFrame*, QString const&, double, QString const&) + 1493
21  QtWebKit                       0x00c385ea QWebFrame::render(QPainter*, QRegion const&) + 42
22  QtWebKit                       0x00c4f5ab QWebView::paintEvent(QPaintEvent*) + 107
23  QtGui                         0x0209c1c2 QWidget::event(QEvent*) + 3410
24  QtWebKit                       0x00c4f85c QWebView::event(QEvent*) + 76
25  QtGui                         0x020444bf QApplicationPrivate::notify_helper(QObject*, QEvent*) + 175
26  QtGui                         0x0204a43b QApplication::notify(QObject*, QEvent*) + 379
27  org.fritzing.Fritzing         0x0001cfa1 FApplication::notify(QObject*, QEvent*) + 49
28  QtCore                         0x02c34492 QCoreApplication::notifyInternal(QObject*, QEvent*) + 98
29  QtGui                         0x01fe9b0b QWidgetPrivate::qt_widget_event(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3899
30  com.apple.HIToolbox           0x963730a9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
31  com.apple.HIToolbox           0x96372370 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
32  com.apple.HIToolbox           0x963721cf SendEventToEventTargetWithOptions + 58
33  com.apple.HIToolbox           0x9639a245 HIView::SendDraw(short, OpaqueGrafPtr*, __HIShape const*, CGContext*) + 475
34  com.apple.HIToolbox           0x96399b99 HIView::RecursiveDrawComposited(__HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 713
35  com.apple.HIToolbox           0x96399e0c HIView::RecursiveDrawComposited(__HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1340
36  com.apple.HIToolbox           0x96399e0c HIView::RecursiveDrawComposited(__HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1340
37  com.apple.HIToolbox           0x96399e0c HIView::RecursiveDrawComposited(__HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1340
38  com.apple.HIToolbox           0x96399e0c HIView::RecursiveDrawComposited(__HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1340
39  com.apple.HIToolbox           0x96399e0c HIView::RecursiveDrawComposited(__HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1340
40  com.apple.HIToolbox           0x96399e0c HIView::RecursiveDrawComposited(__HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1340
41  com.apple.HIToolbox           0x96399e0c HIView::RecursiveDrawComposited(__HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1340
42  com.apple.HIToolbox           0x96398bbf HIView::DrawComposited(short, OpaqueGrafPtr*, __HIShape const*, unsigned long, HIView*, CGContext*) + 873
43  com.apple.HIToolbox           0x96398805 HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 83
44  com.apple.HIToolbox           0x96398755 HIView::Render(unsigned long, CGContext*) + 45
45  com.apple.HIToolbox           0x963a1b88 FlushWindowObject(WindowData*, void**, unsigned char) + 754
46  com.apple.HIToolbox           0x963a58a7 _FlushWindow + 78
47  com.apple.HIToolbox           0x963fd4f9 PostActivateEvent + 419
48  com.apple.HIToolbox           0x963fca82 HiliteAndActivateWindow + 418
49  com.apple.HIToolbox           0x963fc7f6 AdjustToNewWindowActivation(WindowData*, WindowContext*, OpaqueWindowPtr*, unsigned char, WindowData*) + 174
50  com.apple.HIToolbox           0x963fc513 PotentiallyAdjustActivationOnOrderIn(WindowData*, WindowData*) + 167
51  com.apple.HIToolbox           0x963fa34d ShowWindow + 91
52  com.apple.HIToolbox           0x9663448e TransitionWindowWithOptions + 2919
53  com.apple.HIToolbox           0x96634cda TransitionWindow + 75
54  com.apple.HIToolbox           0x96513d46 AlertCommon(short, unsigned char (*)(OpaqueDialogPtr*, EventRecord*, short*), short, short*) + 634
55  com.apple.HIToolbox           0x96513f4e StopAlert + 26
56  ...rack-software.testgenplugin 0x2fcb1df1 MAC_Alert + 186
57  ...rack-software.testgenplugin 0x2fcb207c STR_Vprintf + 630
58  ...rack-software.testgenplugin 0x2fcb20a2 STR_Printf + 27
59  ...rack-software.testgenplugin 0x2fcfb48f ERR_Printf + 65
60  ...rack-software.testgenplugin 0x2fcfc12b ERR_FormatAll + 126
61  ...rack-software.testgenplugin 0x2fcfc1f6 S_ErrPrint + 47
62  ...rack-software.testgenplugin 0x2fcfc2f2 ERR_FrameDefReport + 71
63  ...rack-software.testgenplugin 0x2fcfb8b5 ERR_Signal + 299
64  ...rack-software.testgenplugin 0x2fcfba9d ERR_Fail + 322
65  ...rack-software.testgenplugin 0x2fd8b10c RLibFindLibFileEditReq + 105
66  ...rack-software.testgenplugin 0x2fd8b2c7 RLIB_LoadLibFile + 124
67  ...rack-software.testgenplugin 0x2fd8e804 EEPLUGIN_InstallLib + 475
68  ...rack-software.testgenplugin 0x2fc91fbf CTGEQ::Initialize() + 75
69  ...rack-software.testgenplugin 0x2fc9a94f InitializeNetscapePlugin() + 11
70  ...rack-software.testgenplugin 0x2fc840ed NPP_Initialize + 11
71  ...rack-software.testgenplugin 0x2fca8b7b NP_Initialize + 251
72  QtWebKit                       0x00c63893 qWebKitVersion() + 3331
73  QtWebKit                       0x00c63cff qWebKitVersion() + 4463
74  QtWebKit                       0x00aee8f7 WTF::fastRealloc(void*, unsigned long) + 5135847
75  QtWebKit                       0x00ae8fb2 WTF::fastRealloc(void*, unsigned long) + 5112994
76  QtWebKit                       0x00ae93a8 WTF::fastRealloc(void*, unsigned long) + 5114008
77  QtWebKit                       0x00af5b2b WTF::fastRealloc(void*, unsigned long) + 5165083
78  QtWebKit                       0x00c2c724 qt_dump_resource_load_callbacks(bool) + 20004
79  QtWebKit                       0x009b4903 WTF::fastRealloc(void*, unsigned long) + 3849715
80  QtWebKit                       0x009bba4b WTF::fastRealloc(void*, unsigned long) + 3878715
81  QtWebKit                       0x00b8701f WTF::fastRealloc(void*, unsigned long) + 5760271
82  QtWebKit                       0x0091a38f WTF::fastRealloc(void*, unsigned long) + 3217535
83  QtWebKit                       0x0077b62f WTF::fastRealloc(void*, unsigned long) + 1518367
84  QtWebKit                       0x0077b68f WTF::fastRealloc(void*, unsigned long) + 1518463
85  QtWebKit                       0x0078d860 WTF::fastRealloc(void*, unsigned long) + 1592656
86  QtWebKit                       0x0077f733 WTF::fastRealloc(void*, unsigned long) + 1535011
87  QtWebKit                       0x007806fc WTF::fastRealloc(void*, unsigned long) + 1539052
88  QtWebKit                       0x007bd969 WTF::fastRealloc(void*, unsigned long) + 1789529
89  QtWebKit                       0x007be7a5 WTF::fastRealloc(void*, unsigned long) + 1793173
90  QtWebKit                       0x0077fca1 WTF::fastRealloc(void*, unsigned long) + 1536401
91  QtWebKit                       0x00945378 WTF::fastRealloc(void*, unsigned long) + 3393640
92  QtWebKit                       0x0094599e WTF::fastRealloc(void*, unsigned long) + 3395214
93  QtWebKit                       0x009b8d6f WTF::fastRealloc(void*, unsigned long) + 3867231
94  QtWebKit                       0x009b6796 WTF::fastRealloc(void*, unsigned long) + 3857542
95  QtWebKit                       0x009e5f1b WTF::fastRealloc(void*, unsigned long) + 4051979
96  QtWebKit                       0x009e5941 WTF::fastRealloc(void*, unsigned long) + 4050481
97  QtWebKit                       0x009e6213 WTF::fastRealloc(void*, unsigned long) + 4052739
98  QtWebKit                       0x009e6810 WTF::fastRealloc(void*, unsigned long) + 4054272
99  QtWebKit                       0x009e80cb WTF::fastRealloc(void*, unsigned long) + 4060603
100 QtWebKit                       0x009e8b89 WTF::fastRealloc(void*, unsigned long) + 4063353
101 QtWebKit                       0x009e9a42 WTF::fastRealloc(void*, unsigned long) + 4067122
102 QtWebKit                       0x009a1654 WTF::fastRealloc(void*, unsigned long) + 3771204
103 QtWebKit                       0x009b19cd WTF::fastRealloc(void*, unsigned long) + 3837629
104 QtWebKit                       0x009c538a WTF::fastRealloc(void*, unsigned long) + 3917946
105 QtWebKit                       0x009c56cb WTF::fastRealloc(void*, unsigned long) + 3918779
106 QtWebKit                       0x009f2a56 WTF::fastRealloc(void*, unsigned long) + 4104006
107 QtWebKit                       0x009c5cf2 WTF::fastRealloc(void*, unsigned long) + 3920354
108 QtWebKit                       0x009c96a8 WTF::fastRealloc(void*, unsigned long) + 3935128
109 QtWebKit                       0x009c9b02 WTF::fastRealloc(void*, unsigned long) + 3936242
110 QtWebKit                       0x00c39f22 QWebFrame::setHtml(QString const&, QUrl const&) + 706
111 org.fritzing.Fritzing         0x001bf1d7 HtmlInfoView::setContent() + 311
112 org.fritzing.Fritzing         0x0023d167 HtmlInfoView::qt_metacall(QMetaObject::Call, int, void**) + 231
113 QtCore                         0x02c39d1a QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 570
114 QtCore                         0x02d6ab52 QTimer::timeout() + 50
115 QtCore                         0x02d1fef8 QObject::event(QEvent*) + 424
116 QtGui                         0x020444bf QApplicationPrivate::notify_helper(QObject*, QEvent*) + 175
117 QtGui                         0x0204a43b QApplication::notify(QObject*, QEvent*) + 379
118 org.fritzing.Fritzing         0x0001cfa1 FApplication::notify(QObject*, QEvent*) + 49
119 QtCore                         0x02c34492 QCoreApplication::notifyInternal(QObject*, QEvent*) + 98
120 QtGui                         0x020445dc QApplication::activeModalWidget() + 156
121 QtGui                         0x01ff0241 non-virtual thunk to QDesktopWidget::~QDesktopWidget() + 1985
122 com.apple.CoreFoundation       0x927c476b __CFRunLoopRun + 8059
123 com.apple.CoreFoundation       0x927c20f4 CFRunLoopRunSpecific + 452
124 com.apple.CoreFoundation       0x927c1f21 CFRunLoopRunInMode + 97
125 QtGui                         0x01ff0850 non-virtual thunk to QDesktopWidget::~QDesktopWidget() + 3536
126 QtCore                         0x02d11441 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 65
127 QtCore                         0x02d1166d QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 189
128 QtCore                         0x02d139ce QCoreApplication::exec() + 174
129 org.fritzing.Fritzing         0x0002ccb5 main + 117
130 org.fritzing.Fritzing         0x00005cfc _start + 210
131 org.fritzing.Fritzing         0x00005c29 start + 41
Jonathan Cohen 8 years, 10 months ago
Hi Bruffner,
Looking at the stack trace, the crash occurs in the TestGen plugin, so it looks like there might be some incompatibility between TestGen and Fritzing.   You might try temporarily disabling TestGen (if that's possible), then testing Fritzing again.  Let us know what happens.
Thanks.
- j
Thanks, I couldn't disable it but uninstalling by removing the "/Library/Internet Plug-Ins/npTGEQPlugin.plugin" directory worked quite nicely.  (no idea why it was installed anyway)
