OSX Crash on start
stephenE 8 years, 9 months ago
I looked through some previous OSX Crash threads and this seems different. Just downloaded the lastest release (2010-09-30 for mac universal) and dragged the unzipped folder into my applications folder. Start the program and I get the splash screen with progress bar, the breadboard/schematic/pcb changer appears, and then the main window with breadboard view shows for about half a second before it quits. Get the mac "fritzing cannot be opened because of a problem" dialog. Heres the dump from it:
Process: Fritzing [6879] Path: /Applications/fritzing.2010.09.30.mac/Fritzing.app/Contents/MacOS/Fritzing Identifier: org.fritzing.Fritzing Version: ??? (???) Code Type: X86 (Native) Parent Process: launchd [200] Date/Time: 2010-10-17 11:01:16.096 -0400 OS Version: Mac OS X 10.6.4 (10F569) Report Version: 6 Interval Since Last Report: 81 sec Crashes Since Last Report: 1 Per-App Interval Since Last Report: 7 sec Per-App Crashes Since Last Report: 1 Anonymous UUID: D26FE76E-F455-4F74-B35B-F28322E54565 Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes: 0x0000000000000002, 0x0000000000000000 Crashed Thread: 0 Dispatch queue: com.apple.main-thread Dyld Error Message: Symbol not found: _EVP_idea_cbc Referenced from: /usr/local/lib/libssl.0.9.8.dylib Expected in: /usr/lib/libcrypto.0.9.8.dylib Model: MacBookPro1,2, BootROM MBP12.0061.B03, 2 processors, Intel Core Duo, 2.16 GHz, 2 GB, SMC 1.5f10 Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 256 MB Memory Module: global_name AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), Atheros 5424: 2.0.19.10 Bluetooth: Version 2.3.3f8, 2 service, 19 devices, 1 incoming serial ports Network Service: Ethernet, Ethernet, en0 Network Service: AirPort, AirPort, en1 Serial ATA Device: ST9500420AS, 465.76 GB Parallel ATA Device: MATSHITADVD-R UJ-846 USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8501, 0xfd400000 USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x7d100000 USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0217, 0x1d200000 USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8240, 0x5d200000
Hrmm that code window didnt work as well as I had hoped, heres it just pasted
Version:         ??? (???)
Report Version:  6
Dyld Error Message:
and also thanks in advance! This looks like a great project. Can't wait to get started.
Also, if this helps:
Console Messages from start to crash
10/17/10 11:21:49 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "registering font family: Droid Sans"
10/17/10 11:21:49 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "registering font family: OCRA"
10/17/10 11:21:51 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "empty label /Applications/Fritzing.mac/parts/obsolete/artreeno.fzp"
10/17/10 11:21:51 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "empty label /Applications/Fritzing.mac/parts/obsolete/controller_arduino_diecimila.fzp"
10/17/10 11:21:52 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "empty label /Applications/Fritzing.mac/parts/obsolete/pcb-plain-150x200.fzp"
10/17/10 11:21:52 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "empty label /Applications/Fritzing.mac/parts/obsolete/pcb-plain-200x300.fzp"
10/17/10 11:21:52 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "empty label /Applications/Fritzing.mac/parts/obsolete/pcb-plain-250x250.fzp"
10/17/10 11:21:52 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "empty label /Applications/Fritzing.mac/parts/obsolete/pcb-plain-60x100.fzp"
10/17/10 11:21:52 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "empty label /Applications/Fritzing.mac/parts/obsolete/pcb-plain-75x100.fzp"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "checking for backups"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "looking in backup dir /Users/Stephen/.config/Fritzing/backup/0a27d92524903c93854fcdd914c6580b"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "looking in backup dir /Users/Stephen/.config/Fritzing/backup/d1cc57811df8a109676d73f2c5257ced"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "looking in backup dir /Users/Stephen/.config/Fritzing/backup/eb3eefb9124dc18f8c9abf62a9c3c4c8"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "load previous 0"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "check files to load 0"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "load last open"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "empty sketch"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "Illustrator and inkscape:/Applications/Fritzing.mac/parts/svg/core/icon/microphone.svg"
10/17/10 11:21:53 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "Illustrator and inkscape:/Applications/Fritzing.mac/parts/svg/core/icon/usb_connector.svg"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "Illustrator and inkscape::/resources/parts/svg/core/icon/rectangle_pcb.svg"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "Illustrator and inkscape::/resources/parts/svg/core/icon/rulericon.svg"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding layer kin 3501 3 20"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding layer kin 3502 3 22"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding layer kin 3503 3 15"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding part id:3500 'Jumper' hex:3ac5800 vid:3 vlid:17"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "delete item (2) 3500 Jumper 3 3ac5800"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "removing kin 3501 9.5"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "removing kin 3502 11.5"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "removing kin 3503 3.5"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding layer kin 3521 3 22"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding part id:3520 'Rectangular PCB - Resizable' hex:30d5c00 vid:3 vlid:13"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding part id:3540 'Generic Bajillion Hole Breadboard' hex:1a561f60 vid:1 vlid:1"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding part id:3540 'Generic Bajillion Hole Breadboard' hex:1aa2bc70 vid:2 vlid:1"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding part id:3540 'Generic Bajillion Hole Breadboard' hex:1aad6190 vid:3 vlid:1"
10/17/10 11:21:54 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] "adding part id:3560 'Rectangular PCB - Resizable' hex:385ac00 vid:2 vlid:447621944"
10/17/10 11:21:55 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] dyld: lazy symbol binding failed: Symbol not found: _EVP_idea_cbc
10/17/10 11:21:55 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946]  Referenced from: /usr/local/lib/libssl.0.9.8.dylib
10/17/10 11:21:55 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946]  Expected in: /usr/lib/libcrypto.0.9.8.dylib
10/17/10 11:21:55 AM [0x0-0x3fd3fd].org.fritzing.Fritzing[6946] dyld: Symbol not found: _EVP_idea_cbc
10/17/10 11:21:55 AM com.apple.launchd.peruser.501[200] ([0x0-0x3fd3fd].org.fritzing.Fritzing[6946]) Job appears to have crashed: Trace/BPT trap
10/17/10 11:21:55 AM ReportCrash[6951] Saved crash report for Fritzing[6946] version ??? (???) to /Users/Stephen/Library/Logs/DiagnosticReports/Fritzing_2010-10-17-112155_SEmrich.crash
Jonathan Cohen 8 years, 9 months ago
Hi Stephen,
Two questions.  Did you also get a stack trace?--if so, please post it as well.  Second, we ended up building two different mac binaries with this release, one labeled "Mac OS X" and the other "mac osx 10.4".  Would you mind downloading and trying the other release to see if the results are any different?
Thanks.
- j
The 10.4 specific download launched fine and I was able to make a simple circuit and use autotrace on the PCB view. Seems solid.
I'm not sure how to get a stack trace - google wasn't much help to me there. Willing to learn though.
Thanks,
~Stephen
Thanks for the update.
Usually the when the mac crashes, there's a report dialog that comes up, and when you save that report to a file, it includes a stack trace.
In terms of the crash, there's a fair amount of web traffic on the "symbol not found _EVP_idea_cbc" that seems to be related to certain versions of OpenSSL.   Do you have any sense whether the openssl library (/usr/local/lib/libssl.0.9.8.dylib) comes standard on your mac?
- j
Ok, I think I know what you mean now. It has all the threads and then the massive cascading trace. Unfortunately none of the crashes seem to have provided such for Fritzing.That first post contains the whole thing that crash reporter stored in my log files.
As for the libssl.0.9.8.dylib I did follow that file path and found it there, as well as an alias simply called libssl.dylib. When I try and have the alias "show original" it says the original item cannot be found. Executing openssl -version in terminal gives me "OpenSSL 0.9.8l 5 Nov 2009"
Hopefully that helps a little
~Stephen
dirk 8 years, 9 months ago
As far as I can see openssl comes standard on Mac OS X. I'm running Snow Leopard, 10.6.4, and my libssl is located in `/usr/lib/` instead of in `/usr/local/lib/`. I also have "OpenSSL 0.9.8l 5 Nov 2009". I also have this symlink `libssl.dylib` but in my case it points correctly to the libssl.0.9.8.dylib in the same directory.
Maybe if you just fix that symlink to point to the right lib, it might all work.
The new Fritzing, 0.4.3, works fine on my machine.
HTH, Dirk
Just looked in usr/lib and found it also has libssl.0.9.8.dylib as well as .0.9.7 and .0.9 and that symlink.
Trashed the libssl.0.9.8.dylib in usr/local/lib and now the program launches and runs fine, so it seems it was a quirk with my setup rather than an issue with the coding.
Haven't seen any ill effects from the removal yet... will let it sit in trash limbo for a while.
Thanks for your help Dirk and Jonathan
