Stripboard / veroboard issues
amundsen 4 years, 9 months ago
In the breaboard view, I am using a stripboard. However, what I want is not a stripboard but rather a veroboard (layout with individual points rather than strips). A veroboard preset without any strip would be welcome otherwise one has to remove all the existing copper connections.
Second, with a big (but not unrealistic) size (20 x 50) Fritzing is disastrously slow when setting / removing a connection or when moving a component on the board.
So any improvement would be welcome !
nekomatic 4 years, 8 months ago
This is only a pedantic note, not an answer to your request, sorry, but Vero think a Veroboard is a stripboard. I guess you want an 'individual pad board'.
André Knörig 4 years, 8 months ago
André Knörig
Hi amundsen, we call that a "perfboard" and you can find it to the left of the "stripboard". It's also much faster than the stripboard, because you cannot cut/merge between individual holes.
The stripboard's performance could indeed be improved, but it's not on our short-term agenda I'm afraid. You can improve it somewhat by using multiple smaller ones, because the calculation time rises exponentially with the number of holes per board.
amundsen 4 years, 7 months ago
Actually I do want to merge/split holes, whatever the name of the actual thing. I'll try with smaller boards for parts which do not need to be connected. Thanks.
Russbo 4 years, 7 months ago
I second this. I'm trying to create a stripboard that is only 10 columns larger than stock, not only does it make every connection which I don't want, but the program hangs and is then unacceptably slow from there on out. I need to have a large board for my circuit.
Even if this program is single threaded, a 4.4GHz 4770K is definitely not an issue here. The threads are hardly even being stressed. This just strikes me as bad program design.
As an update, I think I may have found the issue.
Under Windows, Stripboard works fine using Intel graphics. I was using it successfully with large stripboards on another computer. However, using my R9 series AMD GPU, Fritzing was extremely slow and crashed when using stripboard. I belive this is a graphics driver related issue.
This is using Haswell CPUs (one mobile part, one desktop part) and different graphics architectures.
