create "pins" for a cartridge in my pcb design
needle 8 years, 10 months ago
i'm tryin to create a PCB
it only holds an 27c322 eprom and 2 capacitors
so i thought this would be very easy..
turns out i'm busy for three hours tryin to find a a way to create the pins....
with pins i mean the part of the PCB that go into the cartridge slot.
Jonathan Cohen 8 years, 10 months ago
Hi Needle,
If I understand you correctly, you're trying to place some copper strips along the board where it will fit into a slot.   Sorry, but I don't think there's a straightforward answer, and you will have to improvise.
Depending on what's acceptable (and whether my guess about what you need is correct), I could suggest a couple of approaches.  One idea would be to drag out a couple of Vias to mark the opposite ends of each strip, change the size of the via's hole and ring using the widgets in the inspector, then draw a trace between (you can also make the trace thinner or thicker by selecting it and selecting from the "width" widget in the inspector).
Another option would be to create a custom part using the parts editor.  Start out by editing a mystery part (the one with the question mark on the icon), and for the pcb view image,  maybe you can find a useful svg in the parts/svg/contrib/pcb folder that you'll find in the folder where you installed Fritzing.
Hope that helps.
- j
thanx for the reply :-)
you're correct:
i'm going to try and make a custom part, thank you for your help.
Eight 7 years, 2 months ago
I know this is an old thread, but is there a better way of doing this yet? Maybe we could have the option along the lines of importing an image/shape but instead of appearing on the silkscreen, it could go onto the copper layers?
Sorry, just realised you can already set an image to be on a copper layer - anyone know if that could be used to create a card edge or would you maybe have to find a way to trim the silkscreen also?
Jeez I'm stupid tonight - sorry for the spamming the board. I didn't mean silkscreen - I just meant that if I put an image on the copper layer, will anything be over the top of that preventing the shape from being used as a conductor or in this case, an edge connector?
Jonathan Cohen 7 years, 2 months ago
Hi Eight,
If you use a copper image, Fritzing won't let you draw a trace to it, since it doesn't count as a connector. But if your edge connector is a series of rectangles, then consider using the Pad part, which is a resizeable rectangle that includes a connector, so you can draw traces to it. You could start with a single pad part, get the size and position right, then make copies and offset them. You could also do both, make a copper image, and then overlay it with pad parts.
HTH,
- j
Aaah - that sounds just the job. Thanks Jonathan - I'll give that a whirl. I was scared I'd have to try and learn a different software package for this project... which I really don't want to - I love Fritzing. :-)
PS. As of version 0.7.5 (just released) you can put pads on either copper1 or copper0.
Leif Bloomquist 4 years, 7 months ago
Leif Bloomquist
Any luck with this?  I'd love to have something like this as well, and not have to reinvent it.
lissacoffey 4 years, 7 months ago
