10 LED Bar Graph
anonymouse197 9 years, 5 months ago
Would it be possible to have a 10 LED Bar Graph as a part. I understand that it is a bit of a quirky part, but it would be very useful for many projects that I do. For now, I will just use 10 LED's in a row, but that makes it look like a bit of a mess.
Thanks for the help, Anonymouse197
Jonathan Cohen 9 years, 5 months ago
At least for now, you could also consider starting with a mystery part or generic ic, then using the inspector to set the right number of pins, chip width, chip label, etc.  If you're feeling more ambitious, you could try using an SVG editor like Inkscape or Illustrator to create a breadboard image for the part, then using the parts editor to swap that in to your mystery-part- (or generic-ic-) based part.
Cheers,
- j
