change breadboard type deletes parts
JointTech 8 years, 2 months ago
I was working with the Full breadboard.  I switched it to Full+ and all my neatly arranged screw connectors disappeared.  changing back to Full didnt bring them back.
The IC and a few other parts were rearranged on the breadboard.
Not a showstopper now that Iknow it will do that. And you dont really need to change breadboards that often ;)
thanks for a great program.
Jonathan Cohen 8 years, 2 months ago
Hi JointTech,
When you switch breadboards (or other parts), Fritzing attempts to preserve connections by using the connector name.  If Fritzing can't find a matching connector, it should just disconnect the part, but leave it present.  I have so far been unable to confirm the disappearing parts bug.  Can you send us your sketch file to try out (email it to info .at. fritzing .dot. org).  If you're using custom parts, save the sketch as shareable and email us that.
Thanks.
- j
