Hi from West Yorkshire England
Dante 4 years, 9 months ago
Hi
I'm new to electronics and to using Fritzing (which I like very much).   I've created my first circuit design and am at the stage where I will export to pcb.  Everything checks out OK.   However I have one particular item that has given me some concern.
The pcb is double sided with traces on both sides but components only on the top.   When I look at the pcb (top) on screen I see some red areas that are annotated CONNECTOR (0) Copper fill.   Is there something that I must do in relatiion to these connectors?   I intend to make the pcb myself (toner transfer).
If somebody can give me some guidancce here it would be greatly appreciated.
Dante
nekomatic 4 years, 9 months ago
This is just provided in case you want to make a connection to the copper fill - if you hover the mouse over it you'll see the wire spool icon showing that you can click and drag to create a trace to link it to another pad. It won't affect your pcb artwork.
