PCB view ratsnest connections not matching breadboard
mcschaefer 3 years, 3 months ago
I am a new user of Fritzing. I just created a breadboard layout of a circuit I am designing. After finishing it, I went to PCB layout to begin laying out my PCB and the very first trace I clicked on does not match the conncetions I made in my breadboard. It seems as though the pins of the 7 segment LED's are shifted over by one.
I noticed that the particular 7 segment LED part I was using actually had incorrect pin assignments in this exact way. So I deleted all of the instances of that 7 Segment LED on my breadboard and replaced them with a different 7 segment LED that has the correct pin assignments. The issue still persists and I am at a standstill until I figure out how to solve this. Any help would be greatly appreciated!
Operating System: Mac OSX Yosemite 10.10.2
Fritzing Version: 0.9.2
Zoomed in breadboardPCBFull Breadboard
Seems like my photos aren't posting. Here are Flickr links:
https://flic.kr/p/teg4iP
https://flic.kr/p/teg4v2
https://flic.kr/p/syTdSz
picnic 3 years, 1 month ago
I'm having similar sorts of issues. I have a pushbutton switch (where pins 1&2 are connected and 3&4 are connected) On the breadboard I've wired up pins 2 and 3 but the schematic shows that I'm using pins 1 and 2 - there are no pins 3 and 4 (schematic in fact shows 2 pin ones and 2 pin twos). Other wires I have from the microcontroller to a programming header connector are plain missing.
Using beta 0.9.2b if that makes a difference.
