Why do SOME bends "glow"?
mprowe 4 years, 5 months ago
Most of the top layers are "glowing" but the ones between R9 & R11 do not.
Is this usefull information of just a display aberration?
Regards, Martin
jackMiser 4 years, 5 months ago
Do not save that file that is part of a known bug in the program... So Close all instances of Fritzing and re-open. I've seen it myself, others claim lost work. Remember to Backup you're files folks! :D
I REPETE , ***** DO NOT SAVE FILES IF THEY LOOK THIS WAY!!!!!***********
Opps, it has been saved and worked on for some time. Any suggestions to clean it up... ?
Maybe an export and re-import to new project? Or is it trash and I just have to start again.
Dho... it was a "masterpiece" ;-)
Regards, Martin
Fabian Althaus 4 years, 5 months ago
hej, this is a nasty bug. i often fight with it. if you have saved the file, the best way to fix the connection is to drag the bend-point next to the "connector" on to the connector. normaly the "connection-point" and the bend-point switch their positions and the trace is connected again... but better: NOT SAVE - it can take a long time to fix this "jumping-wires". :(
