First PCB Design - Questions + Advice?
About the trace thickness there was a similar thread:
http://fritzing.org/forum/thread/621/?page=all
The page there recommends a for 2 Amps and 35um thickness a with of 30mil
So according to this for 2 Amps the standard thickness with 24mil is too small
Regards
Thomas
Posted 4 months, 3 weeks ago by Heinervdm
Wow, nice job! It is looking very good. You might want to look at the areas again where things are not completely symmetrical, such as the caps in the lower left. I'm also not sure what you have in mind with the jumper wires there, they seem to connect power and ground? But I assume that's just a workaround you put in.
When you start assembling, try to do it step by step and check each part as you go. It's almost certain that at this complexity you will have some mistakes, and this way it's easier to debug.
Good luck, and looking forward to the final piece!
Posted 4 months, 3 weeks ago by André Knörig
Thanks for the great replies!  I thickened up the power and ground lines, and I'm going to spend some time today checking everything against the schematics.  I'll let you guys know how it turns out!
Posted 4 months, 3 weeks ago by mnpumar
Post a Reply
Please login to post a reply.
  • RSS
  • Atom
  • Print this
