Bug with custom parts
Eric_Yang 8 years, 1 month ago
Hi, all
I'm now using the newest version to create some customs part. In the edit window it seems all fine. However, when I drag the part into the breadboard view window, the pins of the part do not appear at the places they should be. They are quite far from the places I put them in the edit window.
bug
Jonathan Cohen 8 years, 1 month ago
Hi Eric,
Open up Fritzing and select your custom part (either in the Parts Bin or in a sketch). Then from the Part menu choose "Export".  Émail the saved .fzpz file to info .at. fritzing .dot. org and we'll take a look.
- j
