Silk top output error
SHCPRODENG 6 years, 11 months ago
In the new version the Silk layer graphics shows up as a solid white page in either PDF or SVG formats. The old version showed this layer as a white text on clear background. I do not know if this is happening because I continued to edit a sketch that I started with the previous version.
Jonathan Cohen 6 years, 11 months ago
Hi Shcprodeng,
There is a bug in 0.7.1 export etchable pdf and svg, in which the copper bottom layer gets both copper bottom and copper top elements (this bug will be fixed in 0.7.2). However, I am not able to replicate the behavior you describe.  Can you email your sketch file to info .at. fritzing .dot. org and we will take a look.  Also, just to be certain, which export option are you choosing?
Thanks.
- j
furiati 5 years, 7 months ago
Hi, I have the same behavior but my version is 0.8.0.
Jonathan Cohen 5 years, 7 months ago
If you email your sketch file to info .at. fritzing .dot. org we will take a look. Also, exactly which export option are you using?
Thanks for answer!
Problem  identified.
The problem is MACOS version, in Windows version no problem. The output it´s OK.
I use only MACOS, if you will can verify this I will thank!
Best Regards.
