this is a time-controlled lighting control system for aquarium LED lamps
This is a time-controlled lighting control for aquarium LED lamps. The time control is stored in control tables in the Arduino code. You can choose between 2 tables (e. g. summer/winter). In addition, the time values can be programmed without a computer connection and the potentiometer allows further adjustment of the desired brightness.
