A thermometer that reads temperatures and displays them.
A thermometer that reads temperatures and displays them on two 7 segment displays. using the accompanying code this thermometer can read temperatures between 0 and 99 degrees C.
parts list
  • 2 x 7 segment displays
  • 4 x 220ohm resisters
  • 23 x solderless cables
  • 1 x tempreture sensor
esmarcat 5 years ago
I am using two different seven segments displays(5161BS and opd-s5620le-bw) but does not work. What is the model used in this project? Thanks.
mitsakos26 5 years, 1 month ago
hello I would ask if possible to convert temperatures (-9and99) I tried but I'm not very experienced and if possible Thanks
Nicolás Andrés Oyarzábal 5 years, 8 months ago
Hi, Matthew! I tried this out and my temperature sensor got crazy hot. Do you know why this could happen or how to fix it? I'm using an UNO board from SainSmart and a LM35DZ from National Semiconductor. Thank you!
