In this project, we will make a simple but functional Arduino Clock using Shift Registers(74hc595) and Seven Segment Displays.
This is a bit complicated build, but if you have some good experiences with electronics and Circuit Building it will be easy for you.
All the code and images are there so there is nothing to worry about, if are good at coding in the Arduino IDE then you could also possibly make your own Arduino Code.
                     GOOD LUCK!!!
