Arduino I2C I/O Expander 14 Digital I/O and 4(8) Analog Input.   MCP23017 x 1 74HC4052 x 1 10Kohm x 2 (For pullup)
You can add 14 Digital I/O and 4(8) analog input easly for Arduino. ;-)
Arduino sample code:
#include <Wire.h> // I2C Lib.
void setup() {
Wire.begin(); //creates a Wire object
Serial.begin(9600);
// set I/O pins to outputs
Wire.beginTransmission(0x20); //begins talking to the slave device
Wire.write(0x00); //selects the IODIRA register
Wire.write(0x00); //this sets all port A pins to outputs
Wire.endTransmission(); //stops talking to device
Wire.beginTransmission(0x20);//begins talking again to slave device
Wire.write(0x01); //selects the IODIRB register
Wire.write(0x00); // sets all port B pins to outputs
Wire.endTransmission(); //ends communication with slave device
void loop()
Wire.beginTransmission(0x20); //starts talking to slave device
Wire.write(0x12); //selects the GPIOA pins
Wire.write(B00000001); // turns on pins 0 and 1 of GPIOA
Wire.endTransmission(); //ends communication with the device
Wire.write(0x13); //selects the GPIOB pins
Wire.write(B00000001); //turns on pin 0 of GPIOA
Wire.endTransmission();//ends communication with the device
Serial.println(analogRead(0));
delay(500);
