Ups, i forgot the picture in my first try to upload this project. Pictures are so improtent, i know. So here is a nother try to upload it with a picture.
You will need:
Arduino Nano
HC05 BT Module
RGB Stripe
Wires
1x 1KOhm Resistor
1x 2KOm Resistor
8x 330Ohm Resistor
2x Switch to cut the connection
to the HC05 BT Mod, when you upload
the Sketch Code to the Arduino
1x Powerplug
8x LED in different Colors if you like.
You can take RGB LEDs if you whant,
that makes no difference.
I set it all on 2 different circuit boards
