I constructed a very cheap and universal plate for AVR microcontrollers but it used to pic ... defoultne is set to atmega8 but only a few jumpers, and may be tiny or XMEGA moment I'm waiting Kim sent her cnc milled from
I constructed a very cheap and universal plate for AVR microcontrollers but it used to pic ... defoultne is set to atmega8 but only a few jumpers, and may be tiny or xmega.zostrojil him because I was nervous neuverzalnost and inconvenience Mayan civilization Starich boards already have oskusane something and I hope you like this design will meet the cost of this board with the fit and are with me € 12 I hope this article has helped someone not hesitate to use my material or modify my dosku.je on it the stabilization of transformer and potential changes in voltage depending on microprocessors eg tiny 3.3V that is changed once a horse (small jumper) You are currently waiting Kim Plank Send me my cnc milled out.
SimonHosa 4 years, 6 months ago
sorry I do not know the Fritzing pages load additional text This board also contains a guidance and a stabilized source of Options 3.3 or 5V. Some chips require 3.3V. The board contains dysplastic of 10 LEDs that are connected to jumpers Pini ATMega these jumpers can be detached and moved to the other pins. There are also two knobs and a small speaker (also linked jumpramy) and ISP interface is preset to jumpramy atmega 8 and also be disconnected and redirected to other pins .Doska is also equipped with five petitions at the wire and LCD 2 * 16 characters 8 cm the LCD are four buttons and the LCD are two RomeRome (adjustment of brightness and contrast) above the keys is GND + 20 * 20 * VCC LCD, buttons, cap I decouple from nothing because of the development capability and chips. [Google Translate]
nedjonik 4 years, 6 months ago
it's okay
