bluetooth controls the arduino uno tell the attiny85 to turn on led strips light.
this is not competly project to be contine please be patient I will update very soon....since I am using Fritzing very first time to do post on this wall.
this project is controls by bluetooth with ledstrips.
to set up for Arduino uno:
int ledPin = 13;
int state = 0;
int flag = 0;
void setup() {
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
Serial.begin(9600); // Default connection rate for my BT module
void loop() {
if(Serial.available() > 0){
state = Serial.read();
flag=0;
if (state == '0') {
if(flag == 0){
Serial.println("LED: off");
flag = 1;
else if (state == '1') {
digitalWrite(ledPin, HIGH);
if(flag == 0){
Serial.println("LED: on");
flag = 1;
to set up for attiniy85:
// color swirl! connect an RGB LED to the PWM pins as indicated
// in the #defines
// public domain, enjoy!
#define REDPIN 7 // attiny PB2 "7"
#define GREENPIN 6 // attiny PB1 '6'
#define BLUEPIN 5 // attiny PB0 '5'
#define FADESPEED 10 // make this higher to slow down
void setup() {
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
void loop() {
int r, g, b;
// fade from blue to violet
for (r = 0; r < 256; r++) {
analogWrite(REDPIN, r);
delay(FADESPEED);
// fade from violet to red
for (b = 255; b > 0; b--) {
analogWrite(BLUEPIN, b);
delay(FADESPEED);
// fade from red to yellow
for (g = 0; g < 256; g++) {
analogWrite(GREENPIN, g);
delay(FADESPEED);
// fade from yellow to green
for (r = 255; r > 0; r--) {
delay(FADESPEED);
// fade from green to teal
for (b = 0; b < 256; b++) {
delay(FADESPEED);
// fade from teal to blue
for (g = 255; g > 0; g--) {
delay(FADESPEED);
