Simple Bluetooth HC-05/06 change name project
just a simple test and work well, in the serial monitor key in "AT" to test whether it work if it work it would say ok, then if you want to change name Beauty then you just key in "AT+NAMEBEAUTY" then if ok it would say OKsetname
