learn how to contorol a motor using a p channel mosfet and a button.
in this project you will learn hot to set up and build a simple device for controling a dc motor. you will use a p channel mosfet instead a standard mosfet. these work in an opisite way to a standard mosfet. when the gate is supplyed power the flow of energy though the mosfet is stoped, but then the gate it grouned the power thought the mosfet can flow freely.
part list
  • 8 x solderlesswires
  • 1 x dc motor
  • 1 x power source
  • 1 x button
  • 1 x p channel mosfet
  • 1 x diode
