Wifi Temperature and Humidity Logger.
LUA Code
pin = 3
Humidity = 0
HumidityDec=0
Temperature = 0
TemperatureDec=0
Checksum = 0
ChecksumTest=0
function get_()
Humidity = 0
HumidityDec=0
Temperature = 0
TemperatureDec=0
Checksum = 0
ChecksumTest=0
bitStream = {}
for j = 1, 40, 1 do
     bitStream[j]=0
end
bitlength=0
gpio.mode(pin, gpio.OUTPUT)
gpio.write(pin, gpio.LOW)
tmr.delay(20000)
gpio_read=gpio.read
gpio_write=gpio.write
gpio.mode(pin, gpio.INPUT)
--bus will always let up eventually, don't bother with timeout
while (gpio_read(pin)==0 ) do end
c=0
while (gpio_read(pin)==1 and c<100) do c=c+1 end
c=0
--acquisition loop
for j = 1, 40, 1 do
     while (gpio_read(pin)==1 and bitlength          bitlength=bitlength+1
     end
     bitStream[j]=bitlength
     bitlength=0
     while (gpio_read(pin)==0) do end
end
--DHT data acquired, processing it :-
for i = 1, 8, 1 do
     if (bitStream[i+0] > 2) then
          Humidity = Humidity+2^(8-i)
     end
end
for i = 1, 8, 1 do
     if (bitStream[i+8] > 2) then
          HumidityDec = HumidityDec+2^(8-i)
     end
end
for i = 1, 8, 1 do
     if (bitStream[i+16] > 2) then
          Temperature = Temperature+2^(8-i)
     end
end
for i = 1, 8, 1 do
     if (bitStream[i+24] > 2) then
          TemperatureDec = TemperatureDec+2^(8-i)
     end
end
for i = 1, 8, 1 do
     if (bitStream[i+32] > 2) then
          Checksum = Checksum+2^(8-i)
     end
end
ChecksumTest=(Humidity+HumidityDec+Temperature+TemperatureDec) % 0xFF
print ("Temperature: "..Temperature.."."..TemperatureDec)
print ("Humidity: "..Humidity.."."..HumidityDec)
print ("ChecksumReceived: "..Checksum)
print ("ChecksumTest: "..ChecksumTest)
end
