this is a pcb board design meant for the dice that i created
parts:
-7-segment display
-arduino nano
-pushbutton
-220 ohm resistor
-the code is up to you however i would recommend using the random seed function and the pins are all digital:
-pins 2-6
-pins8-10
-when placing the 7-segment display, make sure the dot is closer to the pushbutton than the nano;
-when placing the nano make sure the micro usb port is facing away from the 7-segment display
