ethernet tester
ok so this is my first run on fritzing once i dezine part b this part will have some use this is ment to be  a basic tester for ethernet cable i am a novice with fritzing just for you to know
i will howver say  that if you make this i would like to see and the same goes for if you edit my dezine
