If you rotate the knob, numbers will count up and down on the display.
With this Mini Kit you will learn, how to connect a seven segment led display and a rotary encoder.
You will need a micro controller like the Arduino (not included) to run it.
Parts:
1x   mini breadboard
1x   7 segment display (common anode)
1x   knob
1x   wire set
Available at the Fritzing Shop
m2snd 5 years, 5 months ago
Hello. Thanks for the example I am trying to do the same, but it is for 3 digits (3x 7 segment display) for counting 000 to 999. Can you help with de code? thanks
