hey guys, so this is my own flame sensor project , im gonna show you guys how it works. This project is very simple to just prove the basics
ok guys,
so know im gonna explain you guys how i do this flame sensor project since i think the diagram doesnt look that clear for u guys to see...i dont know why is the software like that.. ok so im gonna move on
BUZZER : positive terminal - pin 3
negative terminal - pin GND on the breadboard
LED : positive terminal - pin 7
negative termnial - pin GND
FLAME SENSOR : pin A0 connect to pin A0 on the arduino board
pin GND connect to pin GND on the breadboard
pin + connect to the 5V
and then we proceed with the code:
(You guys are welcome to copy the code)
#include<SoftwareSerial.h>
int sensorPin = A0; // select the input pin for the LDR
int sensorValue = 0; // variable to store the value coming from the sensor
int led = 9; // Output pin for LED
int buzzer = 12; // Output pin for Buzzer
void setup() {
// declare the ledPin and buzzer as an OUTPUT:
pinMode(led, OUTPUT);
pinMode(buzzer,OUTPUT);
Serial.begin(9600);
void loop()
Serial.println("Welcome to TechPonder Flame Sensor Tutorial");
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
if (sensorValue < 100)
Serial.println("Fire Detected");
Serial.println("LED on");
digitalWrite(led,HIGH);
digitalWrite(buzzer,HIGH);
delay(1000);
digitalWrite(led,LOW);
digitalWrite(buzzer,LOW);
delay(sensorValue);
