LED BLINK with adjustable delay using ARDUINO MEGA
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this experiment we are going to see
LED BLINK with adjustable delays:
connect led's to pin 9,10 and push buttons to pin 3,4 and 5v power supply and ground supply as per the circuit diagram .
when one button is pressed it blinks fastly and when another button is pressed it blinks slowly .
