LED Light Chaser with Raspberry Pi
If you completed the Intro to Physical Computing with the Raspberry Pi project, you know how to use the breadboard and correctly set up the wires on a Pi. Your next step is to learn how to program! In this activity, you will create variables, comment on code, and run a setup procedure for the Arduino to make your own LED light chaser.
