An LED lightshow using the raspberry pi and python.
This project is a lightshow consisting of:
- 6 LED lights
- 6 220 ohm resistors
- jumper cables
- breadboard (w/ T-cobbler)
- raspberry pi
Steps to build:
1. Use jumper cable or T-cobbler to connect the GPIO pins of the raspberry pi to the breadboard
2. Insert 6 LED's in a row on the breadboard, with the short leg going to ground and the long leg to a resistor
3. Wire the other ends of the resistors to GPIO 18, 23, 24, 25, 19, and 22.
