LED ON/OFF with two push button using ARDUINO MEGA
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this experiment we are going to see LED'S ON/OFF which is controlled by two push button
connect the LED'S to pin 9,10 and push buttons to 3,4 and give 5V powersupply and groundsupply.
