adapter for microSD card to RaspberryPI standard SD card slot
microSD_adapter_for_rPi.fzz adapter project SD Card.fzpz - SD card fritzing part microSD Socket 112C-TXAR-R01.fzpz - micro SD card socket, which can be soldered without solder paste (contacts are accecible with soldering iron without problem)
microSD socket adasheet: http://gme.sk/img/cache/doc/832/271/slot-sdmicro-1-datasheet-1.pdf
another project I found later:
https://code.google.com/p/raspberry-pi-rs-micro-sd-adapter/
