Some usefull things for older bikes without computer, like fuel elvel, time, gear position. Temperature sensor coming soon.
- Gear position by two method:
      -first: by an joystick, (and an photoresistor), the joystick check, for moves, (and if led from neutral position not light,) it change position. -
      -second, check photo resistor if neutral's led lights it set to neutral the position.
- Fuel level by an potmeter, wich need an rod with a floating something, how it raise, fall the potmeter changes resistance, and it changes fuel level.
- Time with an real time chip it shows the actual hour:minutes in lcd. I use DS1302 (this wasnt avaible in fritzing, so i choose some like this.)
- Lcd display for the datas below this.
