Make a programable interface to the various sensors on the bike, like throttle position and crank speed to use those values to add extra fuel in certain conditions, for example, or to control a supercharger shaft speed.
Parts are:
Adafruit Trinket 5v
Arduino Mini with headers
2 trim pots
wire
code
This is a test bed to prove the code will apply gain corrections  to servo postion values,  based on a lookup, 2D Array on the Trinket.
The Micro is used as a square wave signal source to simulate the crank speed hall effect sensor output, and is adusted by trimpot R2.
R1 simulartes the Throttle Postions sensor, anaolog of 5v.
