Piezo Triggered RGB LED Strip
You can flash the RGB LED Strip with a colour you want by hitting the pressure sensor.
You can flash the RGB LED Strip with a colour you want by hitting the pressure sensor. Adjust the preasure sensitivity with the potentiometer which controls the treshold of the pressure sensor. If the pressure is above the treshold the the LED flashes. If not then the LED will be shining a colour you want (RED in the code).
