Switch power over internet with Telegram.
This projects goal is to switch a webcam off and on in order to reset this camera on a remote location. With this design you do not have to set router port forwards. This device will switch on the power by default, start as a wifi client and connects to Telegram.
To keep the design very simple I used the Wemos(ESP8266+usb), a cheap power adapter and a solid state relais(230V, 2A). Because I only need 1 GPIO to switch there are plenty GPIO's to connect a RGB LED for several status.
Blue blinking = waiting for WIFI to connect
Green = power on the outlet
Red = no power on the outlet
