This is an Arduino-based Proximity Sensor circuit wired using the popular HC-SR04 Ultrasonic ranging module,used here for non-contact object detection purpose. The HC-SR04 module includes ultrasonic transmitters, receiver and control circuit. You only need to supply a short pulse to the trigger input to start the ranging, and then the module will send out burst of ultrasound at 40 kHz and raise its echo.
Components:
1) Arduino UNO, Breadboard, Jumper Wires
2) Ultrasonic Sensor HC-SR04
3) LED
4) 1 kOhm Resistor [x2]
5) Buzzer Sound 5V
6) Transistor BC547
