Simple project to allow turning on/off of an LED via GPIO pin #17.
This project uses: - a Raspberry Pi - a breadboard - a 3mm standard LED - 2 male-female jumpers - 1 male-male jumper (or insulated wire) - a 270o or 330o resistor.
If you just want the LED lit (to test it), move the wire from GPIO#17 to the 3.3v pin on the Pi.
To control it, I used BerryIO from: http://raspi.tv/2012/berryio-a-browser-based-io-control-system-for-raspberry-pi
