RUNNING LED'S USING ARDUINO MEGA
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this experiment we are going to see
RUNNING LED'S
Connect the different color led's to pin 9,10,11
and give 5V power supply and ground.
