I will show you how to control a servo using android phone
things needed:
arduino uno
hc-06
servo motor
male to male jumper wires
android phone
you will need to connect the servo like this
signal to pin 9
vcc to 5v
GND to GND
and the hc-06 like this
vcc to 5v
GND to GND
txd to 10
rxd to 11
and then install an app called (remote control robot)
and connect to your hc-06 and start working
when you open the diagram open it using fritzing and when you open the code open it using thinking pad
