Not everyone wants to torture himself with debilitating diets and wait too long for a treasured disposal of extra pounds. Pharmaceuticals have long offered a lot of "miracle drugs." And in this article you will find out which the most effective diet pills really work, and which do not give any result at all.
Moreover, even the most powerful and effective additives will be ineffective if you ignore the basic rules of admission, disrupt the diet and train in the sex of strength.
Also it is worth considering that for successful elimination of all excess fat, it is necessary to work on fat cells. Any "popular" drugs for weight loss, especially pharmacy options, either have too little effect, or give a temporary result, mainly due to the diuretic effect or effect on the gastrointestinal tract, which is fraught with a mass of consequences. It is important to understand that fat burning is a complex process, for the launch of which only an integrated approach is needed and only a narrow category of additives can provide it.
Of course, the pills can not burn fat by themselves, they only help the body to do this by suppressing appetite, speeding up metabolism and other effects. Let's look at the main groups on the mechanism of action.
Anorexics for weight loss. These drugs are the strongest diet pills and really give results (albeit short-term), because I act by suppressing appetite through the saturation center in the brain. That is, with this kind of pill your body will simply deceive itself, and will not want to eat.
Our comment: the effect of suppressing appetite will be useful when burning fat, but only in combination with accelerating metabolism and maintaining energy. Remember, that for weight loss is still necessary, BUT correctly and often (4-6 times a day)!
Parapharmaceuticals and nutraceuticals. This is not the best diet pills, but only dietary supplements, which differ from each other only in the amount of active ingredients. Weight reduction is achieved through the intake of vitamins and minerals.
Our comment: Such pills can be useful to people with a deficiency of certain vitamins and minerals responsible for the proper functioning of metabolism. If the problem of excess weight is not in this, then they are unlikely to benefit you.
Laxatives and diuretics. The mechanism of this kind of means is understandable - a large amount of water is lost in the urine and liquid stool. But this is completely unsafe for the body, as electrolytes and intestinal microflora are lost.
Our comment: These drugs for rapid weight loss give results in a couple of days, but they do not burn fat! You can get into the jeans by a smaller size due to dehydration of the body, but after a couple of days the water will return to the place, and the washed minerals from the joints - no.
Cellulose. Cellulose helps to cleanse the intestines and rid the body of toxins. Plus, these drugs help to reduce the appetite slightly, because they swell in the stomach and give the illusion of saturation.
Our comment: There is a place to be, if you control your appetite is really difficult. BUT, remember that cellulose has an irritant effect on the intestines and can lead to dysbiosis. In addition, it is proved that not always the feeling of saturation depends on the fullness of the stomach.
Fat Burners. These means for weight loss are the most effective drugs for weight loss, besides it is the most numerous and popular. The mechanism of action of such drugs is complex, and consists in accelerating metabolism, stimulating the thyroid gland and increasing body temperature.
Our comment: This, in combination with physical exercise and proper diet, really works and gives an amazing result.
Ayurslim - Weight Loss pills
Xenical - Super tablets for slimming
New tablet for SLIMMING Lida daidaihua
Compliance with the rules of reception will get maximum effect and avoid any consequences. Good fat burners are basically powerful complexes with a carefully adjusted formula, therefore it is extremely undesirable to depart from the norm of reception, which is prescribed in the instructions.
Depending on the additives and dosages, fat burners are usually taken in the morning, immediately after breakfast. They act even during rest and will accelerate metabolism, increase thermogenesis and reduce appetite. If the intake of the supplement provides 2 or more servings per day, then the second capsule should be taken after dinner. In the presence of powerful stimulants, geraniums or ephedra, it is better to take the second tablet 45-60 minutes before training, but only if it is well tolerated. This will get the effect of pre-exercise and at the same time maximize fat burning.
We have reviewed the most effective diet pills. Some of them will only aggravate your problems, others will give amazing results. You should understand that you throw off kg, that would be better, more beautiful. A beautiful figure is when you have little fat and good proportions due to harmoniously developed muscles. It is the muscles that make the buttocks and hips elastic, and a small percentage of fat emphasizes this beauty. Just skinny buttocks and protruding bones are not enough for anyone. That is, you need not only to take pills, but also to eat and exercise properly, in order to have mouth-watering forms. Change your mind, unfortunately 90% still do not understand how to lose weight properly and we are very upset.
What would be clear is the maximum result from what does not work. We call them thin, but fat. Abroad they are called "skinny-fat". And notice this MAXIMUM RESULT, that is, burned muscles due to a hunger strike or problems with the gastrointestinal tract (liquid stool, nothing is digested)! Do you want this?
Картинки по запросу красивый попы
