A thermistor (thermal resistor) - a resistor that changes its resistance with temperature.
They are popular for basic temperature feedback control.For example, if  you want to have a fan that turns on when the temperature gets high. You could use the thermistor to feed the base of a transistor, as the temperature rises, the resistance goes down, feeding more current into the transistor until it turns on.
