Vacuum cleaners can only remove loose particles from your floor. Just like putting your clothes in the washer, the combination of water, cleaning agents, and physical manipulation is necessary. Your carpet is a filter that traps particles. Like the air filter or oil filter on your car, your carpet can only hold so much. That's why regular carpet cleanings are so important.
Enhanced Carpet Cleaning uses powerful truck mounted machines to deep clean your carpet; removing soil, pollen, microbes, dust mites and chemicals that are brought inside your home on your shoes. These foreign particles trigger allergies and asthma, and may also promote other diseases in young children and the elderly.
Hot Water Extraction Enhanced Carpet Cleaning utilizes the hot water extraction process commonly called “steam cleaning”. The world’s largest carpet manufacturers (Shaw,  Mohawk, etc.) insist on this method of cleaning as the best way to keep you carpet clean and looking new for years to come. Using other methods may actually void your warranty.
Shaw also recommends using IICRC Certified firms like Enhanced Carpet Cleaning. Of the dozens of carpet cleaning companies in El Paso, only a handful meets this requirement. Some companies even try to reduce operating costs by using cold water without cleaning compounds. Regardless of the "great deal" they offer, their "service" isn't worth anything if your carpet isn't clean when they're finished.
Regular deep cleaning also makes your carpet last longer! Soil particles are very abrasive. Even though they are small, these particles wear against the carpet strands so your carpet loses the sheen it had when new. Your carpet is a valuable investment-- make sure it retains its original beauty longer through regular professional cleaning. Ask about the optional Scotchguard® protective spray that helps your carpet resist stains.
 For detail information please visit: http://www.abcd.com.au
