optolink TTL adaptater for Viessmann heater.
this adaptater is used to link your computer to a Viessmann heater via optolink. USB link will be made with a standard TTL-USB module.
Note :
I am having trouble with IR sensor. So consider si this projet as work in progress. I can't read any data from SFH309FA sensor. I don't know why. But I can read some signals from KY-022 module. But I won't be able to read serial data with this module. This module is used in 38Khz modulated signals. This is not the case in Viessmann heaters/controlers.
 Links :
philantier 4 years, 12 months ago
Hello, I bought the board. Hope it will work.
mqu 5 years, 1 month ago
hello, I am happy to notify you mu first implementation of Viessmann P300 protocol IO in ruby : https://gist.github.com/mqu/9519e39ccc474f111ffb best regards.
mqu 5 years, 3 months ago
hello, take care about this. I am having problems with infrared sensor. So do NOT take this piece of hardware as is.
mblo 5 years, 3 months ago
Hello, i can't find which kind of transistor it's for Q2. Have you a finish photo ? Thanks
