A basic Xbee breakout board with access to all the important pins. I would use the acronym but then it would look like my Xbee had BO.
It's not much but it might save someone 5 minutes. I used the SMD version of the socket, you need two with a 2mm pitch and 10 pins to accommodate the Xbee.
Sparkfun PRT-10030
Digikey S5902-10-ND
The design is shamelessly nicked for adafruites's
Xbee adapter. Solder paste is not nessisary for this kind of SMD work.
