NOTE: How to report a problem
André Knörig 6 years ago
André Knörig
If you have a problem with Fritzing, please try to describe it as precise as possible. A good problem report contains:
  • Steps you took that resulted in the problem
  • What you expected should have happened instead
  • Your version of Fritzing and your operating system
  • Any files that relate to this problem: sketches, parts, log files or screenshots
This will make it much easier for us to solve your issue, thanks!
How to send us your related files
  • Send us your file via e-mail to info .at. fritzing .dot. org, and also include a link to the related forum post.
  • dcannam 5 years, 9 months ago
    Tried to make a 12V on/off 555 and did the bread board to PCB. After the PCB's arrived I noticed the capacitor was 180 degree wrong ( see the images attached)
    Is this going to be a problem?
    Jonathan Cohen 5 years, 9 months ago
    Hi DCannan,
    Sorry, I don't understand the issue (and there are no images attached--you have to make them available through a url or send an email to info .at. fritzing .dot. org).
    - j
    flint3 4 years, 11 months ago
    As per André Knörig
    1. describe it as precise as possible. A good problem report contains:
    When you are editing svg art in an external tool (e.g. inkscape) connector lines end up having the space between them filled with black.
    a Steps you took that resulted in the problem Tried Inkscape, Scribus and Libreoffice draw.
    b What you expected should have happened instead Lines that connect on the part.
    c Your version of Fritzing and your operating system Fritzing version 0.7.12 (b6882 2013-02-13) [Qt 4.8.3]
    d Any files that relate to this problem: sketches, parts, log files or screenshots
    This will make it much easier for us to solve your issue, thanks! How to send us your related files
    Since this forum does not have an upload functionality, you have two choices:
    Report your complete problem at our issue tracker, and attach files there. I will not open an issue but rather send a tar ball with the two files attached.
    Send us your file via e-mail to support .at. fritzing .dot. org, and also include a link to the related forum post. I will send a tar ball.
    Thanks, Flint
    utdragbikeracer 4 years ago
    Installed Fritzing on windows 7 profesional keep getting error when I try to run the program (0xc000001d)
    The application was unable to start correctly Have tried reinstalling 4 times now still not opening
    jorlin 3 years, 5 months ago
    First of all, please excuse me for comitting thread necromancy.
    Please people, let's keep this thread clean.
    By all means do file a bug if you encounter one, using the method that is described above.
    Please search the bug forum first to see if the bug has not already been reported, before you file a new one.
    Thanks for the trouble of filing a proper bug report.
    blackmoney 3 years, 4 months ago
    2222222222
