can not delete nets wire in pcb or schematic vieuw
when you add 2 parts in PCB or Schematic vieuw, connect them with a wire and then delete the wire. the nets wire stays connected and is only deletable from breadboard vieuw..
this can get confusing if you don't start building your circuits from breadboard vieuw..
i don't use breaboard vieuw, so after deleting some wires here and there in pcb vieuw, it can get realy difficult to find the nets wires that can only be deleted in breadboard vieuw..
(and having no unnessesary wires will probably make everything run more smooth).
greets G
Hi Gijs,
This is a known issue but is part of a general problem around synchronizing the three views, and so would be dealt with when we decide to tackle the whole thing. So it's going to be awhile.
- j
PS. You can find our list of open issues here: http://code.google.com/p/fritzing/issues.
Post a Reply
Please login to post a reply.
